Limited slip differential question
everhart
Car: 2002 Pathfinder SE
2000 Qx4
Hi, I'm looking at buying a 2000 Qx4
I read that one of the options was a Limited slip differential.
How can I tell is this option was purchased when I go and look at the vehicle?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
On the differential cover there will be a bright orange "LSD OIL ONLY" sticker.
everhart
2000 Qx4
thanks Towncivilian.
this is a 13 year old vehicle and if by chance the sticker has been removed/fell off. Is there any other way to verify?
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
You could jack up the rear end and try spinning one of the rear wheels by hand. If the other tire spins the same way, you have LSD. If it spins the opposite way, you don't.
Alternatively, you could just buy oil with LSD additives and put it in. LSD additives in an open diff won't harm anything.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
He's looking to buy a PF. Changing the oil won't help.
I don't think the LSD was a separate option. It was usually part of a package.
WHICH package in 2000, I don't know.
skiski329
Car: Nissan Altima Coupe 3.5
my 13 year old pathfinder still has the stick on there. kinda surprised me. and i get heavy snow, flooding, salty roads, tons of rust and bits falling off the pathfinder but that sticker is still there.
everhart
2000 Qx4
Thanks guys, I'll check it out. I see it on Sat. I'll report back :)
oh, i know about the strut housing recall is there . So i'll check out the strut housing.
Is there anything that may be an outstanding problem, beside the most typical things that I should double check for
everhart
2000 Qx4
Well I picked the QX4 up this am :dblthumb: no LSD (no sticker was found) everything checked out, so far so good. Here are a couple pics.Image Image
Towncivilian
Looks good! Have it inspected for the strut housing corrosion recall ASAP if it hasn't been yet. It'd be wise to change out all fluids & filters as well. What year is it?
everhart
2000 Qx4
Thanks.
I'll get all the fluids changed soon. I'll have to check the records to see if the PO took it in, I have a stack of Maint. records!
It's a 00 . The one thing I forgot to mention is the drivers door is harder to shut than the others, it almost feels like it's not quite aligned?
Oh and needs the front right 1/2 changed (the boot is ripped) and I'll repack/replace the bearing while I'm at it.
Towncivilian
Mine is misaligned too. Door hinges probably sagged over time/heavy usage. Although my Pathfinder was hit at the driver's side so that may also have something to do with it.
skiski329
so i've never done a 4 wheel drive service (never had 4 wheel drive on my cars) and was looking through the service manual to figure out what to do and found this! this is how you should be able to identify if your have an LSD or not.
"I Limited-slip differential identification.
1. Lift both rear wheels off the ground.
2. Turn one rear wheel by hand.
3. If both rear wheels turn in the same direction simultaneously,
vehicle is equipped with limited-slip differential." Page 27.
NismoPick
Car: 97 Infiniti QX4
00 BMW 528i E39
94 Geo Metro
87 Toyota Pickup
81 Datsun 280ZXT
everhart wrote:The one thing I forgot to mention is the drivers door is harder to shut than the others, it almost feels like it's not quite aligned?
My 97 QX4 had the same sagging drivers door problem. I just opened the door, and slid a 2000lb floor jack under it with a 3ft long 2x4 and jacked it up slightly to just above proper alignment, let it down, and shuts like butter. :)
