Lime Creek Motorsports is the new United States Dealer for Whiteline products.
Feel free to email us for prices on any Whiteline product.A product number is helpful if you are looking for a specific item in our over 5000 item inventory from Whiteline.
[email protected]
This would be a good opportunity for you guys to replace those crappy blown and leaking bushings. Heres a few of the good upgrades for bushings that often go out.
Tension Rod Bushings - Helps to fix high speed vibration and that mushy response caused by poor OEM rubber bushings. I use them on my car and highly suggest them if you are lowered.
Rear Subframe Bushings - Drifters call these "pineapples". They are a polyurethane rear subframe locking kit that solidifies the subframe. It improves rear end feel, 60 ft. times at the track, handling, and drifting.
Rear Camber Offset Bushings - Got camber in the rear? Tired of it? Eliminate .75 degrees of excess negative camber in the rear with one kit. If you nearly drag the ground and have the need for more than one kit then you can order a second kit and it will correct 1.5 degrees of negative camber. Not only will this kit help to eliminate camber bumpsteer during cornering but it will save your expensive tires as well!
Another thing Whiteline offers is adjustable sways. With the ability to adjust the sway bars attitude you can create more understeer or oversteer to neutralize the car. This is a MUST HAVE for anyone that is serious about road racing or optimum suspension performance.
This post is an open offer to the NICO community for the cheapest Whiteline parts arround. Send us an email with any concerns or questions and we'll be glad to get right back to you.
Price requests can be sent to [email protected] and questions can be dirrected to me or alan at [email protected] or [email protected]
Thanks guys.
