sjbsuperman1425 »
https://forums.nicoclub.com/sjbsuperman1425-u80456.html
Mon Jul 27, 2009 7:45 am
my oil temperature gauge is mounted in my oil filter adapter, which i was told would give inaccurate readings due to it being a "pressurized" area, and that i should move my gauge temp sensor to the oil pan. ^Is this correct?
The CA oil pan is steel correct? I just have to remove the pan, drill a hole, weld the bung, and reinstall. Should i use RTV for pan gasket, or what should i use?
I think thats it. Thanks
(btw, Hello again CA Family. Long time no post )
