Positivesstanw wrote:Just curious if anyone would be willing to share what they like and dislike about the car? I am looking to buy one, not sure if I will get a 10 or a 11 and am just wondering if anyone has any glaring issues or things they like a lot about the car compared to other crossovers.
Thanks.
^^ Unless I misunderstood what you said, I believe the car can be put into accessory mode? All you have to do is Push the button while NOT pressing on the brake pedal, it allows 2-3 different position, unless your talking about something else? After 3 presses (with foot off brake pedal) you should be able to turn on everything without having to start the vehicle. Again, unless I'm misunderstanding, sorry.RedwinGV wrote:
Dislikes:
no ability to put in accessory mode from running like you can with a key ignition
True, but that's not what I meant.....zarar wrote:^^ Unless I misunderstood what you said, I believe the car can be put into accessory mode? All you have to do is Push the button while NOT pressing on the brake pedal, it allows 2-3 different position, unless your talking about something else? After 3 presses (with foot off brake pedal) you should be able to turn on everything without having to start the vehicle. Again, unless I'm misunderstanding, sorry.RedwinGV wrote:
Dislikes:
why so? Just leave it in the purse/pocket.ANBYOND wrote:Even with keyless ignition you still have dig through and find/carry the keyloss fob transmitter.
I've found it easier to misplace the fob then my keys too, usually I'm putting the fob in the cupholder, doesn't always fit in my pockets with the keys I have attached. When I have valeted the car, got to remember to give the keyfob, where as the keys would be in the ignition while the car is running etc. I've finally gotten used to it.RedwinGV wrote:why so? Just leave it in the purse/pocket.ANBYOND wrote:Even with keyless ignition you still have dig through and find/carry the keyloss fob transmitter.
Oh and I do wish the cupholder was a bit bigger as well as the door well pockets.
The gas mileage on my EX in my same everyday driving and commute (mostly in town) is the same that my 2008 Accord V6 was, pretty good considering the Accord was 19/29 EPA and the EX35 is only 16/23 EPA.stanw wrote:1. Just curious, why don't you like the pushbutton start? Any particular reason, or just preference?
2. From what I have seen, it seems gas milage is about the same on the EX as with other similar cars, though maybe I have not looked enough.
Really?txgcoupe wrote:Turn off the auto-locks.
