MadSideways »
https://forums.nicoclub.com/madsideways-u3356.html
Wed Jun 04, 2003 4:57 am
Another problem with going wider, which most people don't consider is:
A.) Under dry conditions and under nominal HP the car will handle better.B.) Add some rain / snow / too much HP, and the tires will handle worse than stock...
This is due the fact that your tire patch is stretched out horizontally, which is caused by the weight of your vehicle remaining static, (unchanged). This can be corrected with extra downforce, but then you'd have to be going almost 100mph to acheive that with an APR spoiler:
Formula-1 cars can get away with humongoid tires because they have 1.5-2g's of downforce once they're moving. As a matter of fact, you could flip the track upside down, (once they're moving at decent speeds), and formula-1 cars could continue to race...
