Reno wrote:hey guys i had an idea last night at my Ex's place.. well basically would it be worth it if i get..
1. Crank scraper2. Windage tray3. Aluminum underdirve pulley's4. Aluminum crank pully.5. Rebalanced crank (lightweight if possible)6. Fidanza Flywheel7. 11 lb 1 piece driveshaft.8. Lightweight axles?
what you guys think? would it be too revhappy?
I have been modding cars for over 12 years now and have ALWAYS stood by the "less reciprocating mass = easier rotation" Think of it as your car hole-shotting...
Example...you have a skinny guy standing in front of you facing away... you run and slam into him using a set amount of force. We'll say 5mph and you weight 200lbs.
He'd fly!
Now picture your friend standing but weighing a good 300 lbs... (one tubby tubby) you run at him at 5mph with the same force...you'd barely budge him.
Essentially it works the same way....Newton would agree.
To move a set amount of weight you must use a set amount of force.Albeit that the engine HAS a set amount of force, you can remove weight to make it easier to use the force that you have, hence they rev faster (in the same time making a bit more power, because of lost weight that you dont have to move anymore.
Make the car lighter, make the parts that move lighter, BUT DONT EVER SACRIFICE WEIGHT FOR STRENGTH!!! Only if you are going to change that part INDEFINITELY within a short period of time. I.e. Aluminum Con-rods are used in 3000+hp drag cars...but they are weak so they change them after only a couple of runs.
In a nutshell....Make it ALL lighter, but take strength into account, there is ALWAYS FATIGUE.
I make F1/NASA-Quality Carbon fiber composites, and I KNOW what I'm talking about when it comes to strength/weight/fatigue factors.
Hope it helps...And swap those axles too....,but MAKE SURE THEIR STRONG!
DustinSTiLL RACiNG CEO/Engineer/Driver
