Lightweight crank pulley
al_v
Car: 1998 240sx
Were can I get a lightweight crank pulley for my RB25DET ?????I did a search in google and nico forums , but nothing....
Joe
ive never understood the purpose of a lightweight crank pulley. once you total in your entire rotating assembly (pistons, rods, crank, flywheel, clutch, transmission, driveshaft, rear end, axles, wheels, tires) you realize you are only shaving a fraction of a precent off. sure it may free rev faster but no actual horsepower benefit.
a underdrive pulley or damper does have a purpose, but not a "light weight" one.
just my opinion.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
^^What he said^^
mello88
Car: s13
Check out the ATI damper:
http://www.rocketindustries.co...issan
It's been discussed here on NICO RB forum, search for "ATI Damper"... Here's some more info in a discussion over on HybridZ.org:http://forums.hybridz.org/showthread.php?t=99884
Modified by mello88 at 4:20 PM 8/24/2007
Sil240
Car: Nissan S13 "The One Cam Wonder"
http://www.unorthodoxracing.com
Check under Dyno's upper right hand corner (i believe)300zx
The Rb pulley's are similar in weight to the VGThe RB20 pulley is i think 8-9 lbs
al_v
Car: 1998 240sx
Sil240 wrote:http://www.unorthodoxracing.com
OK , then the vg30 pulley fit in the rb25 ????
StricNyne
ROSS Crank pully FTMFW all aussies use it contact jim @ compulsivehorsepower.com about it
