Lightweight Crank Pulley/belts
Ksizz13
Car: 1990 Nissan 300zx
I think i am buying an unorthodox pulley.being underdrive where can i find belts to fit and which ones will i need.?please help
coolz
Car: 1994 300ZX Convertible
If you purchase it from a reputable place you will get the belts with the pulley. Don't forget the overdrive water pump pulley to get the fan and WP back to the correct speed.
Ksizz13
please explain, if i get the UR crank pulley, what else do i neeeeeed?
coolz
Go to http://www.conceptzperformance.com or http://www.z1motorsports.com. They have kits that are slightly less money than buying from Unorthodox directly. Their sites will tell you what you need. Resist the temptation to buy it on Ebay. If you use an underdrive pulley you slow down everything driven by the puleys. The power stearing and alternator do not make a great deal of difference. Slowing down the water pump is another story. You can buy a smaller pulley for the water pump to get it back up to factory speed. Have you got the tools and know how to install the UD pulley?
Ksizz13
I would have it installed by a pro
z33nismo12
Car: Blue z33
Well the funny thing is that you dont need a belt... The pulley doesnt need a belt to drive the crank.. It sends a wireless signal to your crank, which tells it to drive.. come on its 2008, who uses pulleys anymore..
Ksizz13
go drive ur moms car mike
Jaykit
Car: 1990 JDM Fairlady Z32, Twin Turbo, 2+2, Silver
Just go to either of those sites listed above and buy it all together as one. They will send you everything you need including the right belt size to fit on the new pulleys.
With the unorthodox underdrive pulleys what happens as you will see when/if you take the old one off and put the new one on is that the crank pulley is slightly smaller and quite a bit lighter. In order to compinsate for the loss of turns on the waterpump, the pulley must also be reduced in order to keep the revolutions the same, so as to not overheat your engine. Much like a pedal bike.
z32323
Car: z32
coolz wrote:Go to http://www.conceptzperformance.com or http://www.z1motorsports.com. They have kits that are slightly less money than buying from Unorthodox directly. Their sites will tell you what you need. Resist the temptation to buy it on Ebay. If you use an underdrive pulley you slow down everything driven by the puleys. The power stearing and alternator do not make a great deal of difference. Slowing down the water pump is another story. You can buy a smaller pulley for the water pump to get it back up to factory speed. Have you got the tools and know how to install the UD pulley?
the unorthodox full pulley kit with belts and all accessory pulleys claims it does not underdrive the accessories and that all of the pulleys are the same size as stock. but I don't understand then why they would use different belts..width??
here is my real question..
Is it possible to not underdrive any of the accessories?
Scenario: 95 Stock non-turbo z32 Unorthodox crank pulley, overdrive water pump pulley (if the belts fit????), and then my a/c and p/s of course would be underdriven??
Thanks
Modified by z32323 at 5:17 PM 8/1/2008
JDMZ32
Car: 1991 Nissan 300ZX NA slicktop 5spd red
hey z32323, i saw a thing on the bottom of the main forum page and it said you're Nico's newest member! welcome to nico!
z32323
Car: z32
ha thanx i been readin up on 240s and now Zs for a while but never joined
Mc57127
Car: 1994 300zx TT
I've had my unorthodox crank pulley installed without an o/d water pump pulley for a few 90+ degree days now and my engine temp is the same as normal. The new pulley uses a four groove belt however. Mine only came with a three rib, which has never caused me problems in previous cars.
JDMZ32
i have a pulley question.
the UR pulley sets are listed for either NAs or TTs; you select one.
are they actually different or are they the same?
what i want to know is: if i buy a set for my NA, can i just carry them over to a TT later or would it be a waste of money?
OUKNO
Car: 1990 Z32 NA, 1974 International Scout
Yea you can use it on both NA & TTThe pulleys just have a different amount of grooves on them.SO you can swap with your swap.I asked a question kinda regarding this last week and that is the answer I got on here as well as from My Nissan Tech.
JDMZ32
OUKNO wrote:Yea you can use it on both NA & TTThe pulleys just have a different amount of grooves on them.SO you can swap with your swap.I asked a question kinda regarding this last week and that is the answer I got on here as well as from My Nissan Tech.
thanks buddy! nissan techs are definitely reliable. the two guys at nissan i talk to seem to know everything. it's like they're freaking Z32 robots/computers.
evan_aggie
Car: 1994 300zx na t-top
Old thread, but I had a question regarding aftermarket aluminum pulleys.
I've read it is possible for all of these aftermarket pulleys w/o harmonic dampers to increase the chance of subtle vibration on the crank at specific RPMs.
Overtime, this increase will slowly weaken the crankshaft and then one day (long down the road), BOOM, the crankshaft can go.
Is anyone else not worried? The only problem is, I can't really find a cheap crank pulley with a damper. I found one by ATI but it is almost $450...not to mention it weighs 6.5 lbs versus the 2.5 lbs for the aluminum w/o damper.
pagemaster
Car: 2005 Ford Ranger Edge 5spd
people have been running them on our cars for a while I havent heard of it being a big problem at least to date, but you never know in 2 or 3 years peoples engines could start to go pop
skinZ32
Car: 1992 300zx 2+2
i think its only a problem if your pushing over 500 hp
evan_aggie
If all that matters is not having 500+ hp, then I'll be fine.
However, 200 hp or 500 hp, we stick to the same RPM range (roughly), so I'm guessing your statement is based on how quickly you accelerate through the RPM range (and stress the crank) rather than the range itself.
Does that make sense?
JDMZ32
pagemaster wrote:you never know in 2 or 3 years peoples engines could start to go pop
keep in mind, people aren't JUST now putting these on. they've been getting installed for years.
OUKNO
The VG30DE (TT) is so mechanicly balanced that it isn't a issue, like with the little ricer engines that go pop
