topless@vabeach »
https://forums.nicoclub.com/topless-vabeach-u1506.html
Sat Aug 23, 2003 12:31 am
Check the break pedal relay. One of my techs said he had a problem with his probe where his windshield wipers would stop everytime he stepped on the break pedal. Turned out that the relay was going bad causing a load on the system, taking power away from the wipers.
One more question, once you have the lights in the up position, can you turn them on and off. Do they flicker at all when you step on the break pedal. I havent traced out the lighting and motor circuits so I do not know if they are tied together at all when it comes to power.
