MistaZ31turbo »
https://forums.nicoclub.com/mistaz31turbo-u128954.html
Sat Apr 04, 2009 8:24 am
Ok people, here it is a month and change since I have owned this car and I have finally got her to fire up after wiring the fuel pump straight to the battery. (Kinda sucks have speaker wire everywhere). The problem is none of of my lights still work. I have checked fuses and relays and all of them have between 12.2 to 12.4 volts going to them. I just came across the headlight sensor and there is 12v going to the sensor but I dont know if its good or bad. I found the headlight timer and dont know what the hell its purpose is or what it does. I just cant understand how none of these lights are working when not all the light are running on the same harness. If I cant find the issue then Im going to have to rewire the headlights, taillights, turn signals, and electric fan using switches which will make my car look like a NASCAR plus its a lot of work to do. Sorry for the long post but im fresh out of ideas on what to check next. Anyone got any?
