lights stay on!
lionheart1028
Car: 1991 nissan 300zx 2+2 twin turbo
1993 nissan 300zx 2+0 Na
:ohno: i turned off my na but the tailights stay on?i just noticed it and my light switch isnt turned on.what could it be
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
brake light switch, brake light control box, incorrect aftermarket stereo wiring
lionheart1028
where is the brake light switch located.do i just replace it with a new one? i dont think its the stereo cause i installed it months ago and this is the first time this has happened.
evildky
06 Nissan 350Z GT
brake light switch is located on the..............you guessed ti, the brake pedal ;) crawl under the dash it's up there
lionheart1028
lol just bought the part..didnt see the switch on my first look,guess ima have to dig deeper ill just wait til it cools down 95 degree's outside
evildky
06 Nissan 350Z GT
heat index was 100 here today
lionheart1028
Wow! thats a hard part to reach..but it looks like there are two brakelight switches?? am i wrong which one is it..my owners manual doesnt mention it at all...i also located the brake control box disconnected but i dont got one to replace it with $70 for one is alittle steep and i dont know if thats the problem.gonna take the one from my TT and see if it fixes it but my TT is in the paint shop :cry: til the end of the week.
ziptek
Car: 300zx
ok im having this same problem :frown:
soo is it the brake switch? and does that mean i need a new one or what??
emt-z
Car: 1993 red 300zx n/a five speed
one should be the brake switch and the other is likely be the cruise switch. easy way to find it should be to unplug one at a time and check for your brake lights not working
ziptek
Car: 300zx
found out its the brake switch..but now what? does that mean i need a new one?
evildky
06 Nissan 350Z GT
ziptek wrote:found out its the brake switch..but now what? does that mean i need a new one?
only if ytou want to fix it :slap:
lionheart1028
Update: problem fixed
turns out it wasnt the brakelight switch on the pedal but the little plastic stopper that hits the switch when the pedal isnt depressed so i put in a screw in its place and put a nut with nylon on it problem solved thanks evildky!
