lights out
CrypticScorpio
Car: 1992 240sx SE Hatch
hey guys. 92 240sx HB. my daytime running lights work but my low beams dont work and neither do my dash lights. any help.....also my headlight button dosent work. but it dosent pop in so i think its just broken
Modified by CrypticScorpio at 5:20 PM 9/13/2007
CrypticScorpio
Bump.....
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
chech fuses? be more specific
CrypticScorpio
ok. daytime running lights work when i put the highbeams on. front fog lights work when i start the car. the dash lights do not work at all. and my low beams dont work but my highbeams do. no other electrical issues noticed yet. i checked all the fufes and there all fine as far as i can tell(none of the center wires are broken)checked the kick panel and under the hood. only thing i havent touched are the relays cause i dont know how to check those.
icnuthin
Car: 93 s13 350sx. Vq35de
does your side markers work. if not then its def a fuse. mine did that when i tried to run my optional headlights and it touched metal and popped a fuse. if youlook on your panel its the 3rd to last fuse on the left side. i think its a 15amp fuse
CrypticScorpio
thx man. but i narrowed it down to a relay under the kick panel. im gonna change it with a new one this weekend if it works ill post pics of the relay were it is and what the symptoms are for anyone who may have the problem in the future
