lights out on dash, can't find fuse
ciniello
no lights on speedo, tach, fuel gauge etc, the whole inner dash area. can't locate the fuse for this. very confusing. 3 fuse panels, plus not clear in service manual.
Help!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Neither is the model of your car very clear.
Must be contagious.
ciniello
oops, forgot to mention my car is 02 q45 premium
qship96
Car: 1996 Infiniti Q45
Uh-OH I believe the 02+ uses a flourescent type tube bulb to light the main gauges, and it is difficult and expensive to repair, and all too common to have problems before it should.....call a local dealer service dept and describe the problem, they should be familiar with the issue and its repair cost.
ciniello
thanks. i was afraid of that. but i am still hoping it could be a fuse, 1st thing to check, right. but no luck in identifying which of the 3 panels it is on or the fuse #.
ciniello
qship96 wrote:Uh-OH I believe the 02+ uses a flourescent type tube bulb to light the main gauges, and it is difficult and expensive to repair, and all too common to have problems before it should.....call a local dealer service dept and describe the problem, they should be familiar with the issue and its repair cost.
anybody had any luck finding the fuse for this before i have them rip apart my dash as per above/
