180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sun Nov 09, 2003 8:58 pm
hmm personally I think for me, it's a ground connection as it only happens intermittently. I'll go check it out this weekend when I replace my rusted out headlight adjustment screws.
I actually have some pretty weird electrical problems (which I plan on sniffing out during christmas break) where if I have bulbs in my front turn signals, then when I turn on the headlight switch on the combo switch all my turn signals turn on and stay on...and the other thing is that when I hit the emergency blinkers, they'll blink as long as my headlights aren't on. When I pop out the bulbs for the front turn signals, then everything's fine. I suspect foul play in the headlight harness...which I do plan on pulling out and redoing for the most part.
It's a bastard-esque problem when you've got an electrical problem. I even thought it was my combo switch so went to a junkyard to pull one only to my dismay that it wasn't the combo switch. *shakes fist* But I'll tell you what I find this weekend if I happen to find anything in the vicinity of my headlights.
