Lights on during sleepy eye mode?
Elemental
Car: Acura Integra
I was wondering if anyone knew of a way to have the lights on during sleepy eye mode.
also, would a sleepy eye controller change anything? thanks.
asher4857
Car: '89 240SX Fastback
do a search for this and you'll find plenty. a lot of people have asked for this.. i know its something along the lines of cutting a wire that goes to or from the ecu.. not sure which one though.. if not more..
kapower06
on s13's just pull the light control fuse outta the fuse panel on the driver side kick panel.... make sure the lights are how you want them as they will not go up or down until you put the fuse back in...
Florida240sx
Actually you can make them go back up.Hit your highbeams. Little fail-safe trick I learned so if the friendly blue lights don't approve. You hit that so they are up and you make up some electrical BS that your lights are shorting out.Once they go up they won't go back down unless you put the fuse in.
Elemental
Car: Acura Integra
cool. i look forward to trying that out!
Clatch
So let me try to figure this one out, I can put my lights up and turn them on, then pull the fuse, adjust them to sleepy eye mode, and have my lights STILL stay on?! I also can't figure out how you can still have your lights come on in sleepy eye mode when my lights do not turn on intill the are in the full upright position, it must be some sort of relay or something.
Bruno240
this is what you do.
you find the fuse for your headlights. you wire a basic switch u can find radio shack and wire it to one of the wires behind the fuse. So you are basically pulling the fuse when u flip this switch off.
this is also after you have cut the brown wire to get the basic sleepy eye mod.
Then all you do is have the switch on. turn your headlight on. turn the switch off. turn your headlights off. your headlights should stay up now. all you do now is play with your headlight control switch to lower the lights. flip your homemade switch back on. turn your lights back on. BAM!
Elemental
Car: Acura Integra
and from that point you can just leave it like that and play with the switch or do you have to do that every time you want to look like a BADASS!!!?!?!?!
Clatch
Perhaps something like this needs to be invented.
EDIT: Forgot something err, important.
Modified by Clatch at 8:13 AM 9/12/2005
