netfreak »
https://forums.nicoclub.com/netfreak-u110279.html
Wed Dec 31, 1969 5:00 pm
Discovered the other day that the switch in the truck to control the lights no longer does anything. I've verified that all the lights themselves work fine, but no longer turn on with the switch. I pulled the switch out and wired another one up to test, yet it still doesn't work. The fuses looked fine but I'll use a multimeter on them today.
If it does boil down to some weird wire broken inside the dash, is there an easy way to remove everything? The haynes manual isn't too specific on the 521. Also, does anyone know where exactly the headlight and tail light wiring runs? I may just want to splice it into something else
