Lights get brighter at high RPMs
zachattack_5491
Car: Pignose S13 Redtop SR
When I first start my car at night and flip on the lights, all of the dash lights are very dim, and same with the headlights. When I rev the engine up to about 4000rpms everything instantly gets to 100% brightness and they stay like that until I turn my car off. Could this be the alternator?
foress_89
Car: '93 240sx
I would say it's your alternator, have it checked.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
foress_89 wrote:I would say it's your alternator, have it checked.
yes
lancet913
Car: 1996 240sx se
KA24DET @12psi
dude you are cracking me up!!!
I need to change my oil......240Runner's answer "you should just sell your car"
xekushnr
Car: '90 Nissan 240SX Hatch
Test your voltage regulator as well.
zachattack_5491
Alright, I'll go get it checked. I just wanted a second opinion before I went through the hassle of getting it checked. I don't know where my voltage regulator is or how to check it but I guess that's why I have an FSM Thanks guys
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Voltage regulator is toast, get a new alternator.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
sounds lie your voltage regulator is fried or your entire alt assembly is shot, go get it tested n youl end up buyin a new one
biggishjay
Car: 99 civic
my civic does the same thing...its the alt
zachattack_5491
How detrimental would this be to performance? If I drove it around like this for a while would it **** up anything? My local shop has to order my alternator so it's going to be a little while.I think I might just go with the '97 Quest alternator. It costs about $75 more but I think it would be worth it. Any opinions on that?
zachattack_5491
Yupp so I put my new quest alternator in. It still does the same thing. Now they just get brighter at like 2500 RPMs.
xekushnr
Well, that's why we told you that it was probably the voltage regulator (at least the people who's knowledge I can vouch for) and to get your alt TESTED. Go replace your voltage regulator.
zachattack_5491
xekushnr wrote:Well, that's why we told you that it was probably the voltage regulator (at least the people who's knowledge I can vouch for) and to get your alt TESTED. Go replace your voltage regulator.
The voltage regulator is part of the alternator. The alternator was replaced, therefore so was the voltage regulator.
Edit... or at least that's what all the info I've found says. And my alternator was failing anyways. I got it tested, it failed so I bought a new one.
xekushnr
I guess I missed that post where you said you replaced it. I usually overhaul them so thats why I said you should replace the regulator. I should have paid more attention. Still, I would reccommend that you test the regulator on the new alty to be sure and even do a regulator bypass test and compare your readings to specs.
