newb99qx4 »
https://forums.nicoclub.com/newb99qx4-u63806.html
Fri Apr 27, 2007 9:19 am
Hi, I've tried looking for a similar problem in other posts but couldn't find this exact problem.
I have a 99 QX4 and recently had my timing belt, water pump, spark plugs changed. My mechanic took the battery connections off, did the work, re-attached the battery and now I have this problem:
- anytime a door is opened, my headlights and brake lights flash 30 times and I get the clicking noise on the inside. It does not matter if the alarm is on or off, the key is in or out, the car is running or off, or which door is opened to start the flashing.- it also beeps fast with the door open, and key not in the ignition but the second the key is inserted into the ignition it beeps slower and eventually goes off before the lights flashing turns off
Obviously I didn't have any of these problems before repairs were made to my truck. It's a mechanic friend so he doesn't know what's going on and all he did was detach and re-attach the battery so he's confused as well. And of course the dealership said "we'll run a diagnostic check for $90 and it could be 1 hour or 5 hours...depends on the problem."
Any help is appreciated!
