b88dragon »
https://forums.nicoclub.com/b88dragon-u90486.html
Sun Aug 09, 2009 7:30 am
above is a picture of my matshisuti ballast and the harness for my altima sedan headlights.
I've been on countless HID, retrofit forums searchin on how the wiring is done, and i ended up with nothing but a blank stare and an even more confused look.
Been working on these projectors for some time now and now that weather finally warmer i'm hoping to get these babies done by end of august or so, but i need some help regarding a few terms and wiring.
First off, what does it mean to ground something?
Second, the circled part of the picture with the green and black wire, where and how do i wire that to?
Third, What do i do with the rest of the wires? do the red wire that connected to the relay goes to the battery terminal?
The piece that looks like a plug for an outlet what do i do with that wire? is it plug into something in the car?
Fourth, what do i do with the black wires that are coming from each of the piece that has the black and yellow piece that is on the left side of the picture? is that wire suppose to be grounded? and how if so?
Finally what do i do with that last piece on the top right with the piece of metal that is sticking out that looks like a box, what do i do with that? is it connected to something?
Also how would i wire the CCFL rings? I want it to turn on when i have my parking lights on.
And if phenom87 can shed some light on how to wire those r8 style lights as well that would be fantastic.
Thanks in advance to anyone who can help me with this, search again and again but all i've came up with is how to do a retrofit, nothing on clearly how to wire the stuff -_-, so i hope there is someone out there that can help me with wiring issues.
Thanks and THANK YOU for any help.
