mrbean »
https://forums.nicoclub.com/mrbean-u11191.html
Wed Dec 03, 2003 11:02 am
Ok, I've done some research and have some more questions:
1) If I convert my sealed beam lights to H4 lights, besides the actual lamp housing and bulbs, are there any other parts necessary? Will the bulbs connect right to my existing wiring?
2) Do I need seperate bulbs for low and high beam, or are there dual beam bulbs available? i.e. Do I have to get 2 bulbs per lamp or just 1 each?
3) With the H4 housing conversion, I can use regular H4 halogens for now, and then pop in an H4 HID conversion later (if and when I have the money...) without changing the housing, correct?
I think I have a pretty good idea how these things work now, I just need to make sure I have all the details down to know exactly what I need. Thanks again!
