Lighting/Electrical Issue~1990 20 FB
omegahunterbass
Car: 1990 Nissan 240sx
OK, I am having a weird issue that hopefully I can get an answer to. My gauge cluster lights are somehow connected to my interior Dome light. So when I turn my lights on, the dome light is on. Turning the light off results in my cluster going black. Has this happened to anyone else here?? What could be the issue?? HOW do I solve it?? :tisk:
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
errr def either a short, ground, or fuse. I'd start by checking those
s13_chris
Car: 90 240sx Hatch
Haha. Funnier thing is your tails,dash lights,dome light all hooked into same fuse. Theres a wire that goes to the back of your head unit that also if not taped off will ground and pop your dome light fuse. Pull out the liner and make sure nothings rubbing. Electrical you just gotta go out and start ripping s*** apart after you check the simple things.
omegahunterbass
Ok, so I had to replace a Fuse for the Interior lamps. I did that and now, dash (gauge) lights are on when the ligths are off, but the gauges go off when i turn the lights on.... apparently I have a ground wire short... time to try and FIND it... >.>
