Lightening the flywheel?
aogoblomi_03
Car: Making my car go faster
I am thinking of having my flywheel machined, to make it a little bit lighter. Does any one know if this will throw it out of balance or will I be okay?
91nis240
yes if done correctly it will still be balanced, but i do not recommend having this done. After market fly wheels are lighter and in most cases thinner then stock, but they are made out of a stronger compound and built to take abuse. Now your factory fly wheel will loose alot of strength once machined thus more set up for failure when pushed hard
Holisticbeatz
I had my OEM flywheel machined. They only shaved off so much, doesn't really make much of a difference. Might as well go with a Fidanza aluminum flywheel instead.
EnzoRWD
Car: 1997 Volvo 850 T5
any drawbacks to a lighter flywheel? no turbo, so no issues with spooling down. i was wondering about a fidanza, anything to make the ka want to rev a little more :)-Enzo
91nis240
should be no probc. just some getting used to, RPM's will drop quickly between shifting gears
Rownan
I once heard a horror scenario about lightening the stock flywheel and it will make me scared of ever doing that.. An improperly lightened flywheel that might be the smallest bit unbalanced over time could weaken the crank bolts, and at one point in high revs shearing them off, sending the flywheel spinning outward like a saw, cutting off both feet at the ankles....... :eek: :(
Timhttp://www.projectaspec.com
themadscientist
you lose torque on the launch, it revs out quicker though. I had a Toda lightened flywheel in my CA18DE, it was balless on the launch but would just rap out like a bike on the top end so I tried to pick races on the roll.
themadscientist
Eclipse eh, wanna buy a transmission chump?
Silvia007
Car: 93 Nissan 240SX SE Fastback
mang wrote:240's are gay, its called eclipse turbo's pal.
One lamer after another... when will all these kids "who don't even have a car yet" who likes to start crap grow up.
mang
Silvia007 wrote:One lamer after another... when will all these kids "who don't even have a car yet" who likes to start crap grow up.
sorry man, i was at my friends job browsing and i left my account logged in by accident. i went ahead and deleted said post.
Scott McLellan
I am getting a fidanza aluminum flywheel and a SPEC stage 1 clutch kit this next week sometime and will put it in as soon as possible. I'll let you know what it's like.
themadscientist
mang wrote:sorry man, i was at my friends job browsing and i left my account logged in by accident. i went ahead and deleted said post.
Bring the freind to us for his flogging:mad:
tapdeznutz
if anyone wants i have a spare flywheel off of a '96 sitting around. its up for sale
jay
C-Kwik
You can solve the balancing issue by having the flywheel balanced after it is machined.
C-Kwik
EnzoRWD wrote:any drawbacks to a lighter flywheel? no turbo, so no issues with spooling down. i was wondering about a fidanza, anything to make the ka want to rev a little more :)-Enzo
If you are referring to making the KA rev higher, the flywheel is not the solution. There are a couple problems with revving a KA higher.
#1, the KA runs into vibration issues somewhere areound 7500 RPM.
#2, the cams are too mild. The VE drops of dramatically at higher RPM's. Especially after 6000 RPM.
Scott McLellan
There is a difference between making an engine have a higher redline and making it more "rev happy" with better and faster throttle response. I am getting the fidanza flywheel to try and make it more rev happy. It is in the mail right now and I will let ya know as soon as I can get it on.
Ajax
Car: 1991 240sx SE
2010 Mazda 5
I've got the fidanza unit and an ACT. Its helped out a lot in revs, but it really picked up once I added the exhaust. Can't wait to put in headers.
GELLIS2586
Car: 2006 IS350 / previously 1997 240sx se pearl white
If you lighten the flywheel or put a thinner aftermarket one on youll have to replace the clutch master cylinder and slave cylinder in time because the thinner flywheel screws up the compression of the master and slave cylinders and they wear out quicker. When i got my clutch they had to take an 1/8 an inch off my flywheel and that happened to me.
91nis240
yes good point GELLIS a good performance shop will tell you to have this done when putting in a factory flywheel. Most after market flywheels are thinner and have less volume which hence will cause a drop in compression b/c it frees up space.
