JeromeS13 »
https://forums.nicoclub.com/jeromes13-u227.html
Fri Aug 09, 2002 9:20 pm
upside....basically, takes weight off the drivetrain, allowing more hp to the wheels, allowing faster revving. downside....cost and installation. but, if you said you're going to be installing a clutch anyways, its not bad. expect to spend around $400 for a decent one. if i'm not mistaken, the stock flywheel is around 22-23 pounds. a good lightened one will weigh around 9-11.
