I was considering the JUN because of the strength and less likelyhood to warp as compared to the aluminum. I am in the process of working with a local speed shop to turbo my KA24DE, so I would like to upgrade the clutch and flywheel.
However, I realize the aluminum units are lighter but have you or have you heard of any problems with the aluminum units when it comes to high horsepower in the 240?
The estimate for the first stage of my turbo build is no more than 280hp (@wheel), as the bottom end has not been beefed yet. Plans for the built motor will exceed 450 for the daily driver. So I'd like to plan ahead with the clutch/flywheel combo.
I know ACT seems to be the choice around here, however I've had luck with Clutch Masters in the past and my friend's speed shop has used these regularly in their ProFWD Eclipse and street cars. CM's Stage 3 clutch seems good for my application.
So really it's down to the Stillen or JUN flywheel, with obvious differences ... opinions please
