goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Sat Feb 21, 2009 5:04 am
I would think the rear logo on the 90-93 would be the one since it's painted silver from the inside and is its outline is molded into in the center light bar. Remove the silver paint from the inside, build a dam to contain the light around the logo, and run a pair of wires (from the reverse lights?) and install a bulb.
If the weather's right today pull the trim and center panel off the trunk today and take a look. With a screwdriver and a 10mm socket it's all righty-tighty, lefty-loosey and won't take 15 minutes. Take pics of what you find. I wouldn't mind lighting up mine also.
Paul- What are you doing today?
