carlo350z wrote: i was just wondering if it is common for them to make a chattering noise?
Yes...
carlo350z wrote:and does the 2003 350z have a dual mass fly wheel ?
...and yes.
Any light weight single-mass will be a big switch from the Z's heavy dual-mass flywheel - both in terms of (potential) noise and performance The lighter the flywheel you install the more likely it will be that you hear some chatter. Also keep in mind that the lighter weight will not only wind up faster, but it will also drop rpms faster.
I put in an Exedy lightweight flywheel back in mid-May and have been really happy with it. I need to do a write-up & review about the Exedy bits, but I haven't gotten around to it yet. But a few quick bits...
It weighs in at just under 20lbs (the stock dual-mass is 31lbs). I was tempted to go with the light weight flywheel from Jim Wolf (14lbs), but I was a little concerned that it might be a little
too light, and I'm eager to hear Soup's review and opinion of the JWT setup. I also wanted to avoid the possibility (however unlikely) of the ring gear separating from the wheel on the JWT flywheel, that can't happen with the Exedy flywheel since it's a solid piece of cro-moly with the teeth milled out of the billet.
Here's the thing though...the Z isn't a quiet car to start with, I personally don't think that the chatter is noticeable in anything but the lowest speed & ambient noise situations. And it completely changes the behaviour of the car.
That's a nice read!
