Light upgrade? (help please)
sxtrailrider
Car: sedan G 35
Hi I'm going to upgrade to xenon lights on my G35 sedan 03 and im trying to tell what types of bulbs are on my car, how do you tell weather you have HID or Halogen bulbs, I bought the car used and they bulbs have been on the car a long time so I can't tell what types they are by brightness. How do I tell without removing the bulbs how can i check what bulbs are on my car.
smockers83
Car: 2006 G35 Coupe
Check your manual. Or do a search within the G35 forum. But the easiest way to upgrade is just buying the whole lens assembly from an 06 (I think that was the first year with HIDs, but I could be wrong).
smockers83
Car: 2006 G35 Coupe
Are you talking about just the HIDs or the projector lenses? The projectors started the 06 I believe...that's what I was getting at. Someone will let you know for sure.
sxtrailrider
Car: sedan G 35
thanks and just to make sure others know i did search and i couldn't find out. i bought the car used so i don't have any info on the type of light or the package the guy might have or might have not gotten so i need to find out if i have HID or halogen bulbs without taking the bulbs out. is their some type of visual test. my car is the earlier 03 model.
sxtrailrider
Car: sedan G 35
sorry thanks for all your help, but again I'm just trying to figure out if i have halogen or HIDs. if I have HIDs i will just get new (xenon) bulbs, if i have Halogens i would but the conversion kit. So my question is can I, without taking the bulb out, find out what type of bulb i have in my car? that way i can figure out weather or not it is a halogen and HID and than purchase the appropriate bulb (xenon or a xenon HID conversion kit) thank you.
So is there a difference in the light/color that would be noticeable in these older bulbs? or some kind of mechanical hardware that i could see without dismantling the light casing (i just need the bulb not the 06 light casing) thank you. What about just basic bulb ID that i could see and you guys could point me in the right direction.
Thank you for all your help PS: are the Phillips HID xenon conversion kit from xenon pros a good upgrade.
zozoka1212
Car: 08 Infiniti G35x
You can find answer here. This online manual for the G.
http://www.infiniti.com/iapps/techpubs
Also replacement bulbs are here
http://www.sylvania.com/Consum...t.htm
zozo
sxtrailrider
Car: sedan G 35
no available listings for 2003 cars
sxtrailrider
Car: sedan G 35
can I use a bi-xenon kit to replace the separate bulbs i have in the car now? or they don't work in the car (I want to keep the ability of having high and low beams)
Again thanks for all you help
infinititech1
instructions:
1. turn headlights on2. walk to front of car and look at headlights3. determine color of light4. decided whether you have hids or not
hids are a bright white, and normal bulbs are like a dull yellow
gldenchld
Car: g35 coupe
i just bought the 14k bulbs , have to install them this weekend.
WhiteG35Bullet
Car: 03 G35 CoUpE 6Mt
14k bulbs!? Are you insane that is illegally 10K is still not legal, you probably won't get caught but it will sure blind most drivers!
Infiniti have stock HID bulb of 4500K and 8K is the best way to go!
Number1gsxxr
Car: 2004 Infiniti G35 Sedan 6MT
you realize your lights will be bright pink right?
Like this...
4300k-4500k produces the most lumens (light output, i.e. see the best) and is a bright white color.
8000k is more of a blue.
12k is purple.
CoppellStereo
Car: 2007 G35 S Sedan 6MT
why dont you just look at the bulb? i think that would be much easier. also its easy tell by just looking at them on? also HID will have a ballast and stuff
infinititech1
because the ballast are mounted behind the bumper under the headlight
