bluedragonxtl wrote:can someone send me a link that sells the fog light stalk switch for my 3.5se. Went to dealer and quoted me 150$ and my oem fog light that i bough on ebay only 90$......And also what k should i put in my fog. Should i do a lowbeam match (6k right now) or do a yellow fog (4.3k) which one u think looks better.
I've got a question or 2 for you- Did you install the switch yourself?? If so, do you need to remove the steering wheel to install the switch??
I took off the steering column plastics the other day and it looks like there are just 2 screws and a wire harness plug holding the stock switch on and it looks like it lifts/removes vertically out. But, I wasn't sure.....And if I have to take the steering wheel off to remove the switch forget it. (damn airbags)
I know I can tap foglights in or relay another switch but I want to keep a stock look. Any help is appreciated.
Drootz
