This man is correct, the lower guide breaks and goes into the pan and can lead to pronlems if the pieces are small enough to get into the pickup and clog it. My suggestion is pull the valve cover and remove the guide/protector that is attached to the head itself. It breaks and falls on the chain wearing down to metal as it bounces off the chain it also makes a loud rattling noise that sounds as if its coming from the head. Then, pull the front timing cover and remove the lower chain guide. If it is still in piece reassemble and pat yourself on the back. If not then you undo the swaybar, remove the oilpan and have fun cleaning it out and reassembling. This is how I had to do mine and it took alot of patience to remove the pan with the engine in the car, but it can be done. As for the not being mechanically inclined part, I'm not monetarily inclined so I learn by doing it myself as anyone else can also. Not trying to be smart, just buy a repair manual and follow the instructions and it's just like building a model (only a little dirtier)Razi wrote:No need to replace the guide, simply get rid of it.
dont listen to this type of advice...anytime you hear rattling or obvious noise..you know its not what the desighners of the car intended and should be adressed to find the problem as soon as possible..blackRB240 wrote:Let it rattle man. It isn't worth the hassle or the risk. Whoever told you a timing chain will wear a hole in the block or any such BS is fired.
This piece actually is the one that breaks in half across the bolt holes of the guide shown in the pic... take it out to be better safe than sorry in my opion as I have seen this happen to many a KAs. So you have 3 options1. Remove & problem gone2. Leave it, it breaks and the piece is too big to go past the timing chain and into the front cover or....3. Cut the top guide off, it breaks, the pieces is small enough to past the chain and into the front cover getting caught in the chain and doing more damage than you might want to repair.Just my $.02, but ask these guys even the one in the rb link is a ka engine that messed uphttp://forums.nicoclub.com/zerothread?id=364978http://forums.nicoclub.com/zerothread?id=274983http://forums.nicoclub.com/zerothread?id=38129liquid_cool wrote:
as for the top timing guide...i actually modifyed it and made a plate out of it..after talkiing with a rep at nissan usa..he told me it had a duel use...1 was for the guide its self..and the other was to add stregth to the thin area on the top of the head...so i cut off the guide area and sanded the edges and rebolted it down with locktite thread lock...the nismo guy might be wrong..but better safe than sorry in my humble opinion.
