Light problems! need help!!!
T.O 240sx
Car: 95 240sx w/ kouki conversion, Brembo brakes, KYB shocks, CAI, Infinity Sound System
i was wondering if anyone knew what this problem could be... my left sidemarker doesnt work neither does my right corner light. i put brand new bulbs, and new fuses and they still dont work. i have a 97 240sx... thanks
T.O 240sx
EazyBreazy
check the wiring in the connectors, maybe they have gotten messed up.... make sure all the pins on the connectors are where their supposed to be......if that doesnt work ohm out the wires to the source making sure the wiring is still good(should be takes a whole lot of messin up to goof up wires......check the ground they go to if its not good they wont work......try that. and see what it does
steve
T.O 240sx
thanks steve, ill check it out... they were working fine then one day they just decided to f**k up on me... ill get back to u with the results... T.O 240sx
