Light problem 82 280zx
A home for 1983–1989 300ZX owners!
hitbychance
Car: 2008 350z
2008 Dodge Ram 1500 4x4 5.7L hemi
alright guys im having a problem with my headlights on my 280first of all there stick on highbeams when i have the lights on, and secondly my right headlight is dim as a mofo, ive tried the following, take off the headlight switch made sure it work right by using another switch, same result, i check all the ground i could find under the hood, i also cleaned all the contacts inside my light switch, any ideas?? i think its a problem on the inside of the car, let me know if u have any info?
icice9
Car: 280ZX
might want to check the lighting relay in the relay box on the passenger side under the hood.. also check to see if the headlight sensor might be bad as well...
hitbychance
Car: 2008 350z
wheres the relay box??? is it black ??also where is the sensor located?
icice9
Car: 280ZX
they're both located under the hood on the passenger side right behind the charcole canister....
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
check your grounds!, make sure you have a good ground from batt to body, and to the engine, look for any gound wires at or near the headlights, also check any other electrical connectors for signs of fatigue or moisture, clean all contacts with electrical contact cleaner and hit them with a little di-electric grease
hitbychance
Car: 2008 350z
all fixed it ended up being sumthing so simple as a fuse *_*
Return to “300ZX (Z31) Forum”
