light comes on everytime I touch brake pedal?
herewegosteelers
Car: 1991 Nissan 300zx 2+2
1991 2+2 . Everytime I touch brake pedal a red light comes on, then goes out as soon as i release pedal, it looks like a headlight symbol . Anyone know why
adubon
Car: '90 300zx na 2+0 5speed
one of the bulbs is out. I would tell you to use the nifty search feature since this has been covered many times, but just realized the search they have now sucks.
herewegosteelers
yeah i tried searching but it never seems to work. I checked, all the lights are working? Unless there is a light under the lens that runs the whole way across the trunk lid above the key slot?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
yes there are 3 bulbs under taht thing, sounds liek you have 3 bad bulbs, and they are a wierd size to, dealer or specialty supplier on those
andrez
Car: 1990 300zx na / 1995 f-150 4x4 / 05 focus xr4 99 blazer s-10 jacked
hey there is a green box that i had to change back on the driver side light cause i had the same issue but i had no lights out ...i got it at a yard couldnt even tell you the name of the part
txQ45
Car: 91 300zx TT
The bulbs have a specific ohm so just replacing them won't help.. Get the Nissan or one from another Z
Bow Tie Guy
Car: 90 300ZX 2+2
3rd brake light check that all the bulbs match even if they work
mine had a mismatched bulb tooka lot of searching on and off the WWW
herewegosteelers
it was a mis matched bulb in 3rd light thanks
