cluster isn't too bad, think I had to drop the steering column for clearance to get a panel or two out of the way. I'm surious abnout dismantling the HVAC and tackling those bulbs, most of them are dead.top_secret wrote:its as simple as removing the cluster, which isn't that much work. the bulbs are all there.
the hard part would be replacing the ones in your HVAC controls to match... I've never taken that apart.
I'm actually very curious to hear your method. I pulled my HVAC the other day with intentions of doing this in the next couple weeks...attwater wrote:Don't know if anyone is still reading this... I changed colors on the HVAC unit to match my headunit. I wired blue LED's in place of the tiny yellow lightbulb. Looks perfect now! [email protected] - I can explain the process and show the results if anyone is interested. It is well worth the $5 and 15 minutes.
sounds greatattwater wrote:I will post a new thread with instructions for changing out all lightbulbs with colors/leds: hvac, gauge cluster, shifter column, etc... I will try to get it posted (with pics) prior to the weekend.
