! light appearing on dash
swolpoppa
Car: 2004 inifiniti G35 coupe
what does it mean when an ! point light comes on the dashboard of my G35 coupe?
qship96
Car: 1996 Infiniti Q45
What does the Owners Manual say?
Q451990
Tis the season. (!) is the low tire pressure warning signal. From an earlier discussion, Q45Tech estimated that the tire pressure will drop 1 PSI per 10degrees in ambient temperature. So tires that you set at 32PSI when it was 80F outside would be 29PSI at 50 degrees.
My wife could almost predict the outside temperature by if the (!) came on in the morning until I got around to adding a few PSI. I set all of hers around 35PSI cold on a 50 degree day so that there's some room for error on cold mornings... You need to check them every couple of weeks anyhow - there's no such thing as a completely air tight tire/wheel combination.
Heath
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
swolpoppa wrote:what does it mean when an ! point light comes on the dashboard of my G35 coupe?
EJECT! EJECT! EJECT!
Sorry, I couldn't resist.
