phenryiv1 wrote:I also had limited my leg work leading up to the heavy lifts, just to be sure that I kept my weight at a level where I could double it. That was the whole goal- to bench press 200% of my body weight. I read about it in a magazine that about 10% of men can bench press their body weight one time, 2-3% can bench press 1.5 times their body weight, and that less than 1/100 of 1% can bench press twice their weight. I wanted to be in that 1/100 of 1%.
NoStickers wrote:Just gotta bench 5 more lbs and I'll be in that 1% @ 19yrs old. I don't understand why most people don't exercise more. My work outs are fairly easy and don't even take that long.
NoStickers wrote:My bad, misread. Wow, thats crazy and hard to believe.
NoStickers wrote:Ya I guess its pretty close to being true. Why is it important though? I could lose a lot of weight if I didn't do lowerbody and still retain my ~315lbs bench which would then be more than twice my body weight but I would then be weaker overall. You even said that you limited your legs. I don't understand why this would be impressive.
NoStickers wrote:Sounds good to me.
I'm gonna lift and see what I can max out at this evening. When you bench do you arch your back?
NoStickers wrote:Ok I'm not in that hundreth of a percent. I weighed in at 163.5 w/ clothes and did 1 good competition quality rep of 315. I was like damn that was easy so I put 325 on but that extra 10lbs felt like 50. I barely got it halfway up before it started comin back down. I took off 5 lbs and then couldn't even get that off my chest. Oh well, one day I'll get there...
NoStickers wrote:I was taught to arch my back for competitions. Hope you aren't getting it confused with lifting your butt b/c I definitely keep it planted and find it hard to even try to lift it off the bench. When I bench you could probably slide your hand under the middle of my back.
Haha. I lift weights but not as guys do. :pphenryiv1 wrote:In the event that i want to shoot the $h!+ with some guys about the gym, i want to know who else is a gym rat.
Go ahead, brag a bit.
Post your height, weight, age, and reasons for lifting. Other info is optional.
