Lifting engine, intake manifold
AsanBBoy
Is it a good idea to liff the engine out with a point on a intake manifold? My friend says it could cause a vacuum leak. true? possible?
rotorimp
Car: 02 Xterra, 60 IH Metro
Yes it could cause a vac leak. use the exaust if your worried about the causing a leak.
plane16j
Car: 91 nissan 240sx
theres a hole on the intake side of the engine towords the top front.....you have to put a screw in i believe its 14mm and chain it up there......and on the exaust side use the manifold ...chain as close as you can to the rear of the block for balance
