silvia tech »
https://forums.nicoclub.com/silvia-tech-u72042.html
Fri Sep 14, 2007 2:57 pm
The audio qaulity is really crap no offense. I have some questions for you. Does it only happen at a certain RPM or does it only happen on throttle snap. Is it constant. Does it happen when the motor is cold or when it is hot or does it not matter? Next I would take a wooden dowel or screwdriver or a mechanics stethascope and listen to the timing chain portion of the valve cover then to the valvetrain. Is the noise more apparent in the front of the head or over one bank intake or exhaust. depending on the answer to that question remove the valve cover and find out if you still have that pesky timing chain guide. If so I would recommend removing it or if you are uncomfortible with that operation have someone who is comfortible with it remove it
