0range_240 »
https://forums.nicoclub.com/0range-240-u916.html
Thu Jun 03, 2004 12:26 pm
Ive still got a loud ticking coming from my motor, it is definitely metal on metal, and has become slightly louder over the last week or two. It's a constant tick, although only appears above 2500 rpm, and is louder when the car is accelerating in gear, than if just revved in neutral. And makes no noise while the car is decelerating.
btw, I have checked the tensioners on my timing chain and are in good condition still, so for now im leaning away from that possibility
but when I checked my rocker/lifter assembly after the car had been warmed up, two of my lifters had some movement. however it seemed you could move them MORE side-to-side than up and down, but regardless it was enough to be able to make them "tick" when you shook them by hand. furthermore the sound becomes slightly less noticeable when the engine has warmed up. How sure can I be that this noise is being caused by faulty lifters?
