vroom-chirp wrote:when cornering hard in any car the oil is forced to one side of the pan or the other, in turn not as much oil is getting to the oil pump, starving the engine of oil. some people remove the pan and weld baffles in the to keep the oil from slushing too bad..... this is where i got this info
http://cgi.ebay.com/ebaymotors...wItem
Um, all the 240 pans have a baffle plate... may not be the absolute beffiest but it's there.
Also doesn't explain why I don't see this problem w/ other 240's after runs...
I'm going to change the oil to a different weight and see what happens.
Also, my head/oil pump/water pump/timing chain/etc will be replaced this month, so I'll see if that has to do w/ anything.
