evildky wrote:they aren't supposed to compress, there si a checkball inside thats supposed to prevent that, if you can compres them wither there si air in the lifter or the checkball is dirty or sticking and not closing the hole as it should
Castrol 20W50 Synthetic Blend might cure this. Among other things, it's noticeably more slippery.
Several years ago I parked my J30 for a couple of months due to a leaky water pump and waiting to do the timing belt/tensioner/front oil seals/accessory belts change. I had to move the car a couple of times and each time I started it a lifter began clacking louder and louder. Before long I was more concerned about the noisy lifter than everything else. After completing the other work, adding half a quart of the Castrol quieted the lifter and soon after that I completely switched. Have never had a noisy lifter again.
