edwardo928 »
https://forums.nicoclub.com/edwardo928-u28711.html
Fri May 13, 2005 4:27 am
Thanks for all the info. I went down to the shop this morning and took a look. I was planning on buying the rings on line, good viton high-temp stuff, once I had the sizing right. The owner just started laughing when I pulled out my calipers and feeler guages and started measuring the groove diameter, width, etc. "Engineers!", he said. But they are not even close to any standard o-ring...large diameter compared to the cross-section. (By the way, they are circular cross-section to begin with, before time, heat, wear and compression set take their toll.) My shop has 32 new lifters they bought a couple of years ago when he was going to rebuild a V8. (He halted it when he found out it was not cost-effective.) He is selling me them for $30 each, so that's the way I'm going to go. By the way, I suspect the purpose of the o-ring is to make sure the proper amount of oil goes through a by-pass circuit in the lifter and comes out the the top at the rocker pad contact.
