Lifter Nosie How easy to fix or oil problem
240sxrunner
Car: Auto and Computers
One of my lifters is maken a bad ticking nosie. Its it easy to fix or can i not do it my self. I am pretty good about fixen **** on cars i think i could do it. or could it be that i need an oil change soon. I would be changing over to Mobil 1 Full Synthetic would that help it? o and how many quarts do we stick into our engines?
APEXi240
Car: 08 Nissan Versa S hatch
4 quarts. Its probably the lifters ticking. A friend of mine who is a mechanic said ticking lifters aren't that much a problem...is he just being lazy and not wanting to fix it? The lifters on my Sentra ticked for like 60k and nothing bad happened.
1dollar240
I had a friend that had some ticking lifters on an old lebaron. Mechanic told them it could blow up in a matter of weeks. The damn thing ran for like 100k miles.
APEXi240
Mechanics suck, unless you are one, or know one. I don't think ticking lifters is a big deal...then again I don't really know.
Bubba
Car: Road racing
Check the tightness on your spark plugs. Last time my S-13 made a tapping noise, that's all it was.
flip240
Ticking lifters are really not THAT bad, but you can't tell from hearing it. If you know that you have suffered some severe power loss (preferebly compared to the day the car rolled off the lot *NEW*) then you might have a cause for concern, otherwise it shouldn't be a problem. My shop teacher curses Nissan b/c in the past it tended to have problems liket his, and yes, he is a bastard.
GodDrivesA240sx
Car: 1995 Nissan 240SX
ticking lifters are kinda bad because it hurts performance and gas mileage, if the lifters are ticking then one of the valve(s) (intake or exhaust) isn't opening all the way.
WAbernethy
When I hear ticking coming from my engine it means it's time to add some oil. It's usually about 1/2 quart low. Add some and it goes away. I have a "magical" engine, the oil goes in, but who knows what happens to it after that. It doen't leak or smoke and there is no sign of oil contamination in the coolant. I've heard that some cars, even new ones, consume oil and that is supposed to be normal.
Bandit240
Car: 1980 Datsun 720 King Cab
My just eats oil too. Also i had ticking lifters, but i have a "friend" in a junk yard that god me some with low miles for free. They were easy to install.
flip240
The oil is probobly just lubricating the valvetrain better and hiding the noise, but i assure you its still there since it comes back. Really, you just need to pull the valve cover and make adjustments while properly setting the clearences. It isn't neccessary to get new lifters, just properly adjust them.
