I'm using 5w30 full synthetic. I've only done one oil change since I bought the car. I put approxiamtely 1000 miles on it so far. I'm going to go with 10w30 for my next oil change.JT_MONEY_2004 wrote:What type of oil are you using? Maybe a heavier grade would help. Going from 5w30 to 10w30 (mobil1) did it for me and others.
What do you it might be? I know I have noise from the alternator bearing and/or possibly a pulley.elwesso wrote:lino, after listening to it on the phone, its not lifter tick.
My noise sounds internal and the pitch changes with acceleration. It sort of sounds like a sewing machine or a locomotive. It feels like the finesse and silkiness are not there.Q45ver wrote:Guys
You may in fact be hearing lifter noise, but I'm more inclinded to think that someone new to the Q is actually hearing the injectors. They are the noisest I've heard. My car is just broken in with 51K, and it has always sounded this way. I've always used synthetic and changed frequently, so after investigation with my trusty stethiscope determined it to be the injectors.
According to the previous owner, the guides were done in my car. He gave me the telephone number to the mechanic who supposedly did the work. The mechanic was working for Infiniti at the time and did the job for him on the side. I asked him for the phone number for the mechanic and I called him up immediately after I hung up the phone with him. The mechanic did confirm that he had done the work and gave me a brief description of the job. I have no way of confirming this since I have no paperwork and I wasn't there. I'm not sure what reason they would have to lie. I have almost all the other service records though.Q45ver wrote:I see you have loads of posts, so you will obviously have heard lots on the dreaded chain guide saga and have already taken action. I have heard it said that you can hear the results of seriously worn guides. I would think they would have to be in a near castostrophic state to account for really apparent noise varying with RPM.
It is neither lifter nor injector operation then, as only the frequency of the operation would change, not the pitch.lino wrote:My noise sounds internal and the pitch changes with acceleration.
Here's also got the dreaded post chain guide lifter noise on the drivers side bank.. I used a mechanics stethoscope to isolate the noise.. The noise is most present around the ignitor or it seems to be concentrated around the ignitor..3rd Q wrote:Also had one of the dreaded ticking HLA's. Did 3 or 4 BG Quick Clean flushes over a 10 month period and ran BG MOA in the oil in between changes and the tick is mostly gone, usually don't hear it at all. Will do one more flush and hopefully get rid of it altogether.
My engine has only 84k on it and looked pretty clean internally when I did the chain guides. Noise started after that, so maybe I knocked some varnish loose that clogged a ballcheck in the HLA. My ticking also was not there at start-up, only after fully warm did it make noise.
Some have tried the Bilstein or Envirolution engine flushes. I wanted to go the less invasive route.
Paul
djwarner wrote:My '02 Q will ocasionally make lifter noise on a cold start noticable in the garage. It turns out to be a quart low on oil, just like a '60's GM product. Put in a quart and the noise is instantly gone. (been burning a quart every 3K miles).
