Q45tech wrote:Almost never hear or see a clogged HLA on a Q45 engine with proper oil change intervals [90 days]..................nearly impossible to rehabilitate a clogged HLA with dozens of exotic treatments due to tiny orifice size without damaging the bearings.
Once hydrolocked forever crippled without major internal component replacements.
I agree totally, but this problem is usually the result of improper oil change intervals, too much in town driving and other lack of maintenance. Sometimes you get lucky and a $4.00 bottle of lifter cleaner helps and many times the damage is too far gone to do a quick fix and then stick to the proper maintenance schedule. That is why buying a used car even with a documented maintenance history is always a gamble.
I would like to think if his car was hydrolocked due to excessive fuel from a faulty injector that it wouldn't run worth a darn and would be obvious (ie: bent rod, excessive water or oil consumption, etc.), but maybe I'm mistaken and this would somehow affect one of the lifters. Hopefully for this member, he caught the problem early enough to fix it without having to resort to tearing the engine down. We can surmise all we want to, but until he discovers the root of the problem, all we as members can do is provide valid suggestions on what to look out for.
Ted
