NODES wrote:
are the cut outs cover by plastic that you remove?
Update . Had my 09 Versa HB over to the dealer. Walked into the service area (uh oh) and looked around, saw they were putting the lift feet right under the metal edges that you would use when lifting the car yourself to change a tire. Asked a mechanic there if it ever bent the metal edges and he said no. The lift feet were metal, not padded. The metal edges aren't covered by plastic. ( By metal edges, I mean the "channels" or "rails" formed by 2 or 3 pieces of sheet metal being bent together, and running from front to back.
