Stormy »
https://forums.nicoclub.com/stormy-u10626.html
Mon Mar 15, 2004 9:48 am
If you wanted a little more lift, you could do 1 of 2 things. PA makes a 2" body lift the is around $100 and it's far less effort than the 3" kit. The 3" kit there is a lot of extra stuff to do like extend the fuel filler tube, drop the radiator, extend the shifters (transmission and t-case sifter) by cutting and welding a 3" steel spacer, etc. The 2" kit, you don't have to do any of those things.
The other option is to use 2" shackles or 1.5" add a leafs and adjust the torsion bars to level the ride out.
AAL's for $149.95...
Shackles for $49.95...
Rancho makes a "short" AAL but I've seen them cause a leaf to snap.
