C-Kwik wrote:You can't really blame a shop for suspension problems when there are damaged parts involved. Try getting the actual cause of the problem fixed. If you know frame damage exists and that is causing a problem, fix it.
I know, I was just being a ***** because I needed to vent. The reason why I was pissed at them because I had to bring it back like 4 times. Each time, they told me specifically what would fix the problem. I already told them about what had happened with the car, and they "believed" that replacing certain parts (i.e. tension rods, etc) would fix the problem without having to do body work.
And 180fan, I'll go check the firestone's around my area soon; that costs about the same as I've paid so far, o boy.
