License plate Bracket --> no drilling?
DaSerb
Car: '07 M45s
'16 CX9
I was wondering what are you guys using for front LP.
I hate having front plate but I must because IL requires one. I found this but kinda pricey...http://swiftmotorsports.com/index.php?m ... ts_id=1837
and the cheaper version...
http://swiftmotorsports.com/index.php?m ... ts_id=1838
Any ideas for a bracket that does not involve drilling the bumper?
M35 Sport
Car: Infiniti M35 Sport
mexillis
Car: M45s
Can you put it on the dash? Works for MD since the law is "visible from 20ft"
06M4.5
Car: 2006 M45
DaSerb wrote:I was wondering what are you guys using for front LP.
This was going to be my next mod but I haven't seen the size of this product. I would like to install it in the bumper in front of the radiator but I don't know if it will fit.
I can't install it under the aero lip as the car is too low because of the coilovers.
need to find the size (plate and arm when closed). :gotme
06M4.5
Car: 2006 M45
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
That's the s***!! Definitely something I would like!!
DaSerb
Car: '07 M45s
'16 CX9
The Bodyguard
Anyone try these let us know!! This is straight up something I would do!! :dblthumb:
SmoovC
Car: '06 Infiniti M45 Premium, Brakemotive, H-Techs, KYB's, USA-Spec PA15-INFI w/ BT streaming, Kuda cell mount, Magnaflow exhaust. (CAR SOLD)
Current: 2012 Infiniti M56S, Harbour Blue, 4 pc Aero Kit
It says in the item description: "The Swift Hide-a-Plate fits on many vehicles, most Audi's, Volkswagen's, Corvettes, Mustangs, Camaros, Cadillac's, and more. If your car has a flat spot under the bumper that goes at least 10" straight back, and wide enough for a license plate, this should fit on your car too!!"
The Bodyguard
Thanks for pointing that out! :dblthumb:
06M4.5
Car: 2006 M45
I'll take measurements of the hole in the bumper tomorrow when I get a chance. If it has more than 10" I'll order one. :dblthumb:
DaSerb
Car: '07 M45s
'16 CX9
Definitely inside the bumper...less issues when driving in snow or wet roads I think.
06M4.5
Car: 2006 M45
Looks like the plate will fit, I just have to see how deep we can go. I really don't want to see the tip of the plate so we'll need more than 10" space for sure.
06M4.5
Car: 2006 M45
Just got these #'s from my body shop:
12" W x 10.5" L x 1.25" H
Hope this helps, Freddie
06M4.5
Car: 2006 M45
I took a look and it doesn't look like it will fit. I think the space going in is only about 9". :frown:
DaSerb
Car: '07 M45s
'16 CX9
I am assuming 10" is needed for the bracket to fit in. I wonder if bracket can be modified somehow. Maybe cut out an inch of it.
I found this one that requires 9" deep space....http://www.hidetheplate.com/product_inf ... ducts_id=2
Anyways, any ideas on what source to use for power? Maybe parking lights?
06M4.5
Car: 2006 M45
It's the same part.
It's 9" long without the motor.
I wish I had one in-hand so that I can see what could be done to make it fit.
SmoovC
DaSerb wrote:I am assuming 10" is needed for the bracket to fit in. I wonder if bracket can be modified somehow. Maybe cut out an inch of it.
I was thinking ignition for a power source. When the car is running, the plate will be up, when car is off, it will retract. I was under the impression these came with some kind of controller? Not sure exactly what they are referring to by that term.
06M4.5
Car: 2006 M45
All info is in here with pics:
SmoovC
I appreciate you posting the link. I wish they had an install and owner's manual listed. I guess what I am getting at is the fact that with "2 wire hookup", that means most likely constant power and a ground. You would then control the unit with the supplied remotes. I would prefer a unit that does not need a remote to operate; rather operates off of ignition power to flip up and retract. I would also think a unit such as that would lower the price, say to that magic $99 mark.
06M4.5
Car: 2006 M45
Wiring the unit is not a problem, you can wire it any which way you want. Now making it fit in the bumper is the hard part.
Now if you go with the unit without the remotes and the motor I'm sure this can be installed with no problems.
But I want it with the motor. Not having the product on hand to try to install it is my problem.
