Licence Plate LED queston
Bori83
Car: Coupe 3.5 MT
I believe the size for the LED Lights for the licence plate are 194. As verification, what size is the LED light i need? I found this web site http://www.v-leds.com, anyone have different info?
Thanks
JSPADES
Car: 2009 Altima Coupe 2.5S 6MT in Radiant Silver
Bori83 wrote:I believe the size for the LED Lights for the licence plate are 194. As verification, what size is the LED light i need? I found this web site http://www.v-leds.com, anyone have different info?
Thanks
The 194 LEDs should work. While there are several choices, you may want to avoid the "high-power" LED options for the licence plate lights. In communicating with v-leds' customer service, I was advised that continuous long-period illumination of high-power LEDs can shorten their life span. I elected to use the high-power LEDs in the interior lights, since none of them would stay on nearly as long as exterior lights would.
For my licence plate lights, I bought the 5-SMT superwhite LEDs which illuminate the lamps quite nicely without the excess heat often produced with the high-powered LEDs.
-b-
Bori83
Car: Coupe 3.5 MT
B,
Thanks for the Info, that is why i asked i saw some of them said Hi-Power I will purchase the 5-SMT.
Mike
dieseldom
Car: 2008 Super Black Altima Sedan 2.5SL Fully Loaded
Hi guys - quick question --- would this be the same for the 08 sedan?
This is the link to the LED from v-leds.com (http://www.v-leds.com/Exterior-LED/Corn ... 81039.html) --- would you tell me if they are the correct ones?
Much appreciated
-D
JSPADES
Hi, dieseldom,
Those are the ones I bought for the license plate on my '09 A/C. Unless I am seriously mistaken, I believe that the electrical system with regard to lighting on the '08 model is virtually the same as that of the '09. I believe I recall seeing a lamp bulb application thread on here (was it stickied somewhere?) which stated as much. Can anyone provide info to the contrary here?
DReed86
Car: Altima Coupe 2008 SE 3.5 White CVT
Yes those are the right ones any 194 bulb will work.
