placham »
https://forums.nicoclub.com/placham-u38577.html
Sun Aug 31, 2008 7:34 am
For $100 that's a steal, nice find. , your going to love it. Did you get hardware with it. New set only comes with directions (with picture). Bolts that go into turbo, and I think 3 bolts that go onto downpipe. You should have 2 bolts that go onto turbo that are 12pt 10mm, they are the middle ones, go across from each other. Your defenately going to need these 2bolts. If I remember you use 4 out of 6 original bolts, 2 at top and 2 at bottom. Reuse turbo gasket. Or maybe there is 4 bolts and 2 nuts on turbo, IIRC.
I bough a SYKO Performance elbow, for $215 shipped, looks top quality item, fitment was perfect. Did it on the car with motor installed. Was a PITA to remove old elbow. had to use combination of ratchet and wrenches 12mm,13mm, and 1/2". Work space is limited for turning wrench or ratchet.
On S13 I'm using r32 xmember that came with my RB20, stock turbo, and stock RB20 mounts. Clears the steering shaft by about 1/2 to 3/4", I also bought a 3" Sr20 downpipe and test pipe on ebay (cheapest set). Works like a charm, Syko is one of few that make a full 3" elbow, if that's what your looking for. This runs to my Blitz exhaust.
After installing elbow, looks like there is little bit more room between engine and elbow, and puts O2 sensor little bit higher. Noticed this because my O2 and MAF wires are not extended yet, so it has more slack now with this elbow.
I was going to buy an elbow off of ebay, but for like 115 bucks more, you can get so much better quality and fitment part.
